What is GRE tunnel bandwidth?
Tod Larson
Level 3
Level 3
What does the GRE tunnel bandwidth transmit feature do? The default is 8000 kbs but I do get much more than 8meg throughput so I'm having trouble understanding and validating an implementation.
Below is what I find on cisco.com but I don't understand since this makes it seem like my throughput would be limited to 8meg. Thank you.
tunnel bandwidth
To set the transmit bandwidth used by the tunnel interface, use the tunnel bandwidth command in interface configuration mode. To restore the default setting, use the no form of this command.
tunnel bandwidth {receive | transmit} bandwidth
no tunnel bandwidth
Syntax Description
receive
Specifies the bandwidth to be used to receive packets through the tunnel.
Note This keyword is no longer used and will be removed in future releases.
transmit
Specifies the bandwidth to be used to send packets through the tunnel.
bandwidth
Bandwidth, in kbps. Range is from 0 to 2147483647. Default is 8000.
Defaults
8000 kbps
Command Modes
Interface configuration
Command History
Release
Modification
12.3(7)T
This command was introduced.
Usage Guidelines
Use the tunnel bandwidth command to specify the capacity of the satellite link.
Examples
The following example shows how to set the satellite tunnel bandwidth to 1000 kbps for transmitting packets using Rate Based Satellite Control Protocol:
Router(config)# interface tunnel 0
Router(config-if)# tunnel bandwidth transmit 1000
Related Commands
Command
Description
tunnel destination
Specifies the destination for a tunnel interface.
tunnel mode
Sets the encapsulation mode for a tunnel interface.
tunnel source
Sets the source address of a tunnel interface.
Richard Burts
Tod
It is fairly common to assume that the interface bandwidth would control the rate of the interface. But that is not the case. The bandwidth command on an interface is informational and does not, by itself, exert any control.
The bandwidth statement can be used by other processes. For example the calculation of the routing metric for EIGRP is calculated using the configured bandwidth. Many network monitoring and reporting tools use the bandwidth to calculate the usage of the interface. And some QoS and Rate Limiting tools can use the bandwidth to calculate how to limit traffic.
I believe that there is a reference in what you found that says the tunnel bandwidth was used by rate limiting tools:
Rick
Rick
Richard Burts
Tod
Rick
Rick
Tod Larson
Level 3
Level 3
So "transmit bandwidth" looks like a feature that was put in place to support features such as satellite control protocol. But in reality, only scp would use this and I'm not running scp so I can ignore the parameter.
Tod
If I understand correctly what you are trying to do and to understand, then yes you can ignore the GRE tunnel bandwidth transmit parameter.
Rick
Rick
