What is interface St1 ?
kaustav.gupta
Level 4
Level 4
I was checking show spanning-tree
in a Catalyst 4506 switch and found an interface type St1 .
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/1 Root FWD 4 128.1 P2p
St1 Desg FWD 19 128.1000 P2p
What is this interface St1 and what is it used for ?
Thanks in adv
Kas
Hi Kaustav,
Thats right now. The interface is a stacked interface and on 3750 in STP switch stack appears as a single spanning-tree node to the rest of the network, and all stack members use the same bridge ID for a given spanning tree. The bridge ID is derived from the MAC address of the stack master.
Ankur
* Pls rate the post if it helps
9 Replies 9
Collin Clark
Can you post a 'show ip interface brief'?
Show Ip Interface brief does not list that interface.
Regs
kas
prakashrj
Community Member
I have seen that kind of interface on 3750 stack switches.
do you have anything stacked?
I did not understand your query. Can u explain ?
Regs
Kas
Hi Kaustav,
When you have switches in stack then you see an interface as stack1 in your spanning tree status. Like 3750 can be connected with another 3750 in stack so the interafce will be referred as stack.
But AFAIK there is no stack kind of stuff on 4500 so do you have switches like 3750 in stack connected to 4500 switch?
Ankur
3750 stacks are connected to the network but no directly with the 4506 switch
Let me correct myself the interface is appearing in the Catalyst 3750 switch stack. What is this interface used for ?
Regs
Kas
Hi Kaustav,
Ankur
