What is L2 and L3 Static and Dynamic Multicast?
r20039r20039
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Static multicast could be defining static multicast paths and/or defining static multicast members.
Dynamic multicast would use a dynamic multicast protocol, e.g. PIM, and hosts using the dynamic membership protocol IGMP.
If you wondering where you might use static multicast, it's used in somewhat unusual situations.  For example, years ago I needed to push a multicast stream to a sat uplink.  As the sat uplink was unidirectional, dynamic multicast couldn't be used.
Or, during the same time frame I had a mix of Cisco and Brand X equipment.  Brand X supported DVMRP, and Cisco supported PIM and some DVMRP.  I had to do some "static" multicast to share between the equipment vendors.
Can you draw a topology where Static and Dynamic Multicast is separately shown?
Disclaimer
Posting
Not easily.  It's as much if more related to special host requirements and/or network device limitations rather than the topology itself.
