What is my ip address on my switch?
dan_track
I've got a switch with about 70 vlan's and 3 loopback interfaces on it, the switch also does routing. I want to telnet to a device on vlan 66, how do I know what ip the switch is going to use as the source ip address if I initiate the telnet from the switch?
Dan
Collin Clark
I believe it uses the closest interface to the destination (per the routing table). You can always source from an interface if you need to.
Router#telnet 1.1.1.1 /source-interface ?
Async Async interface
Auto-Template Auto-Template interface
BVI Bridge-Group Virtual Interface
CDMA-Ix CDMA Ix interface
CTunnel CTunnel interface
Dialer Dialer interface
FastEthernet FastEthernet IEEE 802.3
Lex Lex interface
Loopback Loopback interface
Multilink Multilink-group interface
Null Null interface
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-Dot11Radio Virtual dot11 interface
Virtual-PPP Virtual PPP interface
Virtual-Template Virtual Template interface
Virtual-TokenRing Virtual TokenRing
Vlan Vlan IEEE 802.1q
vmi Virtual Multipoint Interface
Hope that helps.
