what is NVI0 interface on router
mahesh18
Level 6
Level 6
Hi all,
on my router i see
NVI0 is up, line protocol is up
  Hardware is NVI
  Interface is unnumbered. Using address of NVI0 (0.0.0.0)
  MTU 1514 bytes, BW 10000000 Kbit/sec, DLY 0 usec,
  Encapsulation UNKNOWN, loopback not set
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 04:46:27
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
I have no idea what this interface is used for?
Any answers
thanks
mahesh
Ganesh Hariharan
Hi Mahesh,
The NVI is only used when using "domain-less" NAT.  It is normal to have the NVI shutdown when not using NVI. NVI allows traffic between overlapped VPN routing/forwarding (VRFs) in the same Provider Edge (PE) router, and traffic from inside to inside between overlapping networks.
check out the attached document regarding NVI hope that clear out your query !!
Ganesh.H
Claudio Monge
I have the same configuration but Interface Gi0 is UP UP connected with dual T1s and int fa8 is down down with one T1 as backup. The ISP told me the T1 is UP but I see the int fa8 down yet. Is it a normal behavior?
