What is part 700-37332-01-A0?
theitguy11
I've been installing Cisco 2901 routers. The router comes with a small plastic tab with self-adhesive backing part # 700-37332-01-A0. I'm curious what that part is for.
Leo Laohoo
The  only thing that's "adhesive" in every R & S appliances are the black rubber "tabs".  These are to be stuck on the bottom of the routers in every corner.  Helps minimize vibrations if you don't want to rack-mount them.
bmades
I wondered the same about this part for my 3560C-12.  It turned out to be the cover for the reset switch.
dj.hernandez
Reset button cover. Prevents accidental reset.
