What is the difference between oversubscribed and performance mode port?
Can anyone explain to me what is diferrence between an oversubscribed port and a performance port?. A customer is asking me to configure some ports in a Cisco Catalyst 6807XL Switch some ports in oversubscribed mode and some others in performance mode; but first I would like to understand the difference between those modes.
Thank you in advance!!!!
Leo Laohoo
What line card are you trying to do?
Is a WS-X6904-40G,
Basically I want  understand how do one and the other mode work
6904-40G?  Don't bother.
6800 is currently equipped with Sup2T.  This means the per-slot backplane speed of 220 Gbps.
4 ports of 40 Gbps is only 160 Gbps and NO NEED to configure over-subscription mode.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
In general, "performance" mode there's no bandwidth bottleneck to/from an edge port.
For example, a 6509, with a sup720B supports 40 Gbps to a line card.  So, when the 6708 was released, you could run it in performance mode, where only 4 of its 8 10g ports are enabled (providing each port 10g to/from the fabric) or you could run the card in normal mode, where a pair of 10g ports shared 10g to/from the fabric.  The latter being considered 2:1 oversubscription.
