Not able to recover port from err-disable
shoaib sheikh
Hello All,
I am not able to recover interface from port security violation. Let me know the reason.
Is this related to what this person is saying on the link http://blog.glinskiy.com/2013/02/port-security-side-effect.html.
#show port-security int GigabitEthernet3/0/6
Port Security              : Enabled
Port Status                : Secure-shutdown
Violation Mode             : Shutdown
Aging Time                 : 0 mins
Aging Type                 : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses      : 1
Total MAC Addresses        : 0
Configured MAC Addresses   : 0
Sticky MAC Addresses       : 0
Last Source Address:Vlan   : 0023.245e.f4d7:11
Security Violation Count   : 1
#config t
Enter configuration commands, one per line.  End with CNTL/Z.
(config)#int GigabitEthernet3/0/6
(config-if)#shu
(config-if)#no shut
(config-if)#
Jun 22 03:50:33: %PM-4-ERR_DISABLE: psecure-violation error detected on Gi3/0/6, putting Gi3/0/6 in err-disable state (-3)
Jun 22 03:50:33: %PORT_SECURITY-2-PSECURE_VIOLATION: Security violation occurred, caused by MAC address 0023.245e.f4d7 on port GigabitEthernet3/0/6. (-3)
interface GigabitEthernet3/0/6
 switchport access vlan 11
 switchport mode access
 switchport nonegotiate
 switchport port-security
 no cdp enable
end
(config)#do show mac address-table int GigabitEthernet3/0/6
          Mac Address Table
Vlan    Mac Address       Type        Ports
Doing debug on interface show nothing in output but terminal monitor shows reason for port security violation.
InayathUlla Sharieff
HAs there been any other PC connected to this port earlier?
8 Replies 8
johnlloyd_13
Level 9
Level 9
hi,
could you remove port-security command?
conf t
default int g3/0/6
OR
int g3/0/6
shut
no switchport port-security
no shut
Hi John,
Thanks for reply.That would work but it will disable port security on interface. I wanted just to recover port from error disable.
hi,
you can just configure auto recovery in global config.
the default timer of 300 seconds can also be changed.
errdisable recovery cause psecure-violation
errdisable recovery interval <sec>
use show errdisable recovery to verify its operation.
Hi John,
Thanks for reply. Will try and let u know.
This statement doesn't make any logical sense.
If the port goes into a legitimate error-disable then why enable AUTO recovery?  Might as well remove the command to go into error disable when MAC address >1.
What you're asking to do is like driving down a major highway with one foot on the accelerator and another foot on the brake.
Hello Leo,
I am observing this issue on specific ports not on all ports. for other ports I just do
no switchport port-security mac-address sticky 0023.248f.242e
shut
no shut
It will re-enable port security and automatically starts working for other machines. I dont wanted error recovery automatically, it should be manual,
Hello Inayath,
Accidentally clicked on correct answer . you are right it happened when another PC was connected on that port.
