What is the requirement for two routers to be connected?
pezhmankh
Hello
I am studying for CCNA and I was hoping to learn what is the requirement for two routers to be connected?
I know they have to be on the same network using the same protocols, but what is the role of username and password here? Do they have to have the same username and password?
Sorry your original post did not include anything about using PPP CHAP on the link. So yes in this case as stated above your username on your router must match the *peer* routers hostname, and the passwords should be the same. Note that you do not need PPP CHAP to get your routers to link up, but when you use PPP CHAP you need the same password and you must have a username that matches the *peer* router. So in your reference above you listed Router1 with a username of "router2" but your syntax is incorrect above. Above you have:
Router 1 Config:
Hostname router 1
username router 2 password cisco
interface serial 0/0
ip address 10.0.8.1 255.255.248.0
encapsulation ppp
ppp authenticantion chap
But with the spacing between "router" and "2" this effecively creates a username of "router". So the proper syntax would be:
Router 1 Config:
Hostname router 1
username router2 password cisco
encapsulation ppp
Router 2 config:
Hostname router 2
username router1 password cisco
ip address 10.0.15.2 255.255.248.0
encapsulation ppp
If you notice above the difference between my post and yours is I have removed the spacing in the "username" field after router. This will configure Router 1 to have a username of router2, and Router 2 to have username of router1.
Hope this helps to clarify your issue.
-Toby
Please don't forget to rate any helpful post.
_____________________________________
There are no great limits to growth because there are no limits of human intelligence, imagination, and wonder.
- Ronald Reagan
-Toby
- Ronald Reagan
tobyarnett
Like devices need a cross over cable, dissimilar devices use a straight through cable. The connecting interfaces need to be on the same subnet, and your speed and duplex settings need to be the same. Your username and password are unique per device, those don't need to be the same to link up
-Toby
Sent from Cisco Technical Support Android App
-Toby
- Ronald Reagan
Hello Toby Thank you for your respond.
I was expecting an answer with username and password have to be the same because this was the answer to one of the sample questions I am studying, I'm going to write the configuration to be more clear.
Router 1 Config:
Hostname router 1
encapsulation ppp
Router 2 config:
Hostname router 2
username router 1 password cisco1
encapsulation ppp
And the sample question does also have the answer which is Username/password is incorrectly configured. Are you suggestion the answer is incorrect?
As you do 2 way PPP CHAP authentication then the passwords must be the same and the username on one router must correspond to the hostname of the router you want to authenticate.
Alain
Router 1 Config:
Hostname router 1
encapsulation ppp
Router 1 Config:
Hostname router 1
encapsulation ppp
Router 2 config:
Hostname router 2
encapsulation ppp
-Toby
- Ronald Reagan
-Toby
- Ronald Reagan
