What is uplinks ?
abhdivak
Hello All,
What is the exact meaning of uplinks of device ? Can i call any Ethernet port as uplinks.
Abhijith
Mark Malone
Hi Abhijith
uplinks bring your to the next level of the network like the linls between access level to ditriobution level and the the links to the core switches are all uplinks , usually there trunks in lan but can be routed links either depending on design
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Infrastructure links, that carry traffic "down" toward the edge might be called "downlinks", the converse are "uplinks".  (NB: the same link is both an uplink and downlink, which depends on your reference switch port.)
On some switches, some ports are designated "uplink" ports, regardless of how they are logically used in the topology.  Such ports might be "special" in that they might support higher bandwidth and/or better internal forwarding performance than other ports, might provide more buffering, might support multiple media or non-copper media, might provide a different default for MDI/MDI-X and/or can select MDI vs. MDI-X, etc.
