What is wrong...? vPC question
joyride_us2
Level 4
Level 4
what is wrong :
Nexus1 (5548)
vpc domain 1
role priority 4098
system-priority 2000
peer-keepalive destination 10.100.2.13 source 10.100.2.12
delay restore 150
auto-recovery
interface Port-channel1
swithc mode trunk
switchpo trunk native vlan 998
spanning-tree port type network
vpc peer-link
_______________________
Nexus 2 (5548)
vpc domain 1
role priority 4096
system priority 2000
peer-keepalive destination 10.200.2.12 source 10.200.2.13
delay restore 150
auto-recovery
switchp mode trunk
switch trunk native vlan 998
vpc peer-link
>show vpc
vPC domain Id : 1
Peer status   : peer adjacency formed OK
vPC keep-alive status : Suspended (Destination IP not reachable)
Thank you.
Hey No you should be able to build that live without any issues , basically its just routed vlan across a trunk link so those ips can reach other and keep the hearbeat going between the 2 5ks , once you have that setup that should stop your message ---vPC keep-alive status : Suspended (Destination IP not reachable)  and give you something like vPC keep-alive status : peer is alive
Mark Malone
Hey vpc keep alive goes across layer 3 link
needs to be another separate po , that's routed those ips or use the mgtm ports
see this doc rexample
http://www.netcraftsmen.com/how-vpc-works/
vpc domain 100
  peer-switch
  role priority 200
  system-priority 150
  peer-keepalive destination 10.1.1.1 source 10.1.1.2 vrf heartbeat
  peer-gateway
  ip arp synchronize
interface port-channel1
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 2,10-11,17-18,20,28,31,33-34,36-39
  switchport trunk allowed vlan add 48,50,64-67,70,72,74,76,78,80,90-108
  switchport trunk allowed vlan add 112,226,400,431,490,1226
  logging event port link-status
  logging event port trunk-status
  vpc peer-link
interface Vlan3111
  description EIGRP Routed Subnet
  no shutdown
  no ip redirects
  ip address 10.1.1.1/30
interface port-channel3111
  description Port-Channel to CORE 7K2
  switchport
  switchport access vlan 3111
  switchport trunk allowed vlan none
Thanks Mark.
Do I need to restart anything to get this rolling ?
dukenuk96
Level 7
Level 7
Show full running config please.
