What’s missing from my dhcp?
Pokeswap
I have been practicing on packet tracer. I have A PC connected to FE 0/3 on a switch. I thought I had it configured for DHCP, but I think I’m missing something.
Current configuration : 1827 bytes
version 15.0
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
ip dhcp excluded-address 10.10.0.0 10.10.1.10
ip dhcp pool mainNet
network 10.10.0.0 255.255.248.0
default-router 10.10.1.2
dns-server 10.10.1.2
ip dhcp pool secondNet
spanning-tree mode pvst
spanning-tree portfast default
interface FastEthernet0/1
switchport access vlan 10
interface FastEthernet0/2
interface FastEthernet0/3
switchport mode access
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
switchport access vlan 20
<interfaces excluded for brevity>
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
<excluded interfaces for brevity>
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
interface Vlan10
ip address 10.10.1.1 255.255.248.0
interface Vlan20
ip address 10.10.8.1 255.255.248.0
line con 0
line vty 0 4
login
line vty 5 15
login
end
the IP addresses in the two highlighted lines need to match. So make both either 10.10.1.1 or 10.10.1.2.
interface Vlan10
--> ip address 10.10.1.1 255.255.248.0
--> default-router 10.10.1.2
interface Vlan10
Reza Sharifi
Not familiar with PT but usually the default-router address should be the IP address of the vlan
default-router 10.10.1.1
balaji.bandi
ip dhcp excluded-address 10.10.1.1 10.10.1.10
dns-server 10.10.1.1  < Do you have DNS Server running 10.10.1.2 ? if not i will use router IP or google dns 8.8.8.8
BB
