what's the difference between PEM and PS?
Ray Han
PEM : Power entry module
PS : Power supply
who's know about this?
2 Accepted Solutions
Shashank Singh
There is no real difference. PEM and PS are the modules that supply power to the switch/router. In some cases they also perform the AC to DC conversion as required by some platforms.
For example, PEM was replaced by PS after it became EOL in case of 7600 routers.
http://www.cisco.com/en/US/prod/collateral/routers/ps368/prod_end-of-life_notice0900aecd806b0baa.html
End-of-Sale Product Part Number
PEM-20A-AC
Power Entry Module for CISCO7606 (1900W Pwr Sup)
Replacement Product Part Number
PWR-2700-AC
2700W AC power supply for CISCO7606
In case of some routers (10k series), the power unit is still called PEM.
Cheers,
Shashank
P.S. Please rate helpful posts.
Latchum Naidu
DC Power Entry Module:
The MGX 8850 or MGX 8850/B switch can accept power from a -48 VDC (-42 to -56 VDC) source that connects to one (primary) or two (secondary/redundant) -48 VDC PEMs. Each DC PEM must be connected to a dedicated 60 A regulated source.
AC Power Supply Tray:
The Cisco MGX 8850 switch can accept power from a 220 VAC (180 to 254 VAC) source that connects to an optional AC power supply tray, The optional AC power supply tray houses up to six AC power supplies and is installed directly below the air intake plenum. The AC power supplies convert 220 VAC to -48 VDC power for the switch.
Hope this cleare you...
Please rate the helpfull posts.
Naidu.
Shashank Singh
PEM-20A-AC
PWR-2700-AC
Cheers,
Shashank
Thanks for your help.
it's a good help and have a good time ^^
Latchum Naidu
Naidu.
Thanks for your comments
it's a great help.
Sanghee
