what's the difference between vrf definition and ip vrf forwarding?
Zhixin
I want to config vrf,but i found two config methods:
  vrf definition xxxx
  ip vrf forwarding xxxx
what's the difference between vrf definition and ip vrf forwarding ?
Device info:
WS-C3750X-48 (c3750e-universalk9-mz.122-58.SE2.bin)
Seb Rupik
Hi there,
...is for IPV4 VRFs only.
vrf definition xxx
...is for multi-protocol VRF (ie IPv6) and should be used or migrated to where available.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/mp_l3_vpns/configuration/xe-3s/mp-l3-vpns-xe-3s-book/mp-vpn-ipv4-ipv6.html#GUID-D21ACFBB-B345-496B-91D6-F5A7196095DC
cheers,
Seb.
Thanks for your help.
I will read the guide.
