what's the difference of XFP-10G-MM-SR,SFP-10G-SR and XENPAK-10GB-SR? Can they connect each other?
xiao xu
We are connecting a ASA 10G port with SFP-10G-SR to SCE 10G port with XFP-10G-MM-SR and C7609 10G port with XENPAK-10GB-SR, can they connect each other? or it is manadatory use the same SFP module for the connection?
Jerry Ye
Jerry Ye
The should be fine. According from the data sheet
SFP-10G-SR is 850nm MMF
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
XFP-10G-MM-SR is 850nm MMF
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6574/product_data_sheet0900aecd802a61b9.html
XENPAK-10GB-SR is 850nm MMF
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps5138/product_data_sheet09186a008007cd00_ps5455_Products_Data_Sheet.html
As long as the wave lenght and fiber type matched, they should be able to communicate.
HTH,
jerry
thanks,jerry !!
