What the hell is wrong with my EtherChannels?
10298230434141
Here's the issue. No matter what I try, I cannot seem to get Po1 and Po2 out of the SD state. Please help.
as stated, PT is a bit quirky. Review the attached, working file...
6 Replies 6
Leo Laohoo
IF it is in "suspended" state, then the switch logs would provide the answers.
Okay. I'm using Packet Tracer. Can I find the switch logs from the CLI of the switch? If so, what commands should I use?
post your zipped Packet Tracer project (.pkt) file here. PT has a lot of quirks that might not occur on 'real' switches, you might be running into one of those...
Here it is. The switches that I usually work on are Cisco Catalyst 3650 Series, and I use SSH to configure them remotely as my university's campus is currently closed. However, whoever used the switches before me did a LOT of configurations on these switches and as such, I was unable to erase the NVRAM file system, despite using every command that I know to do so. As such, I recreated the topology in Packet Tracer. I wasn't aware that there were differences between the two - I really only use SSH, because it's easier to open a PuTTY window than to draw a whole network with PT.
Anyway. Here is the file. Ultimately, my goal is to get Po1 and Po2 up and running.
Thank you very much. Might I ask how you went about fixing it?
