Catalyst 3560 swi
rengaraj7733778
pieterh
check your interface settings (baud, bits, parity)
NB! the switch may have other settings than default (9600, 8 , N) -> you need to experiment
if problem exists and you use a USB to Serial adapter, check if this works with another device.
