What will cause if Time zone mismatch between Cisco switch and PA FW
ShankL
this is kind of big question. simply there is no harm to your operations such as traffic passing. issue is coming when you co-relating incident using device logs. you may need to calculate time differences for device logs to compare with each device.
rate this and mark as answer, if this solved your concern
Good luck
KB
Good luck
KB
