whats causing cellular to radio power mode = off
Josiah Inubio
Guys,
Can you please help me with whats causing cellular connection to radio power mode = off? How to prevent it?
Router specs
CISCO2911-SEC/K9    Cisco 2911 Security Bundle w/SEC license PAK
S29UK9-15104M    Cisco 2901-2921 IOS UNIVERSAL
Thank you
25 Replies 25
Leo Laohoo
Look at the "sh logs" to find any clues.
Would be nice if you can post the "sh version" too.
I believe these is whats make the cellular goes to radio power mode = off (based on logs). but whats causing the modem in HWIC goes down?
Logs
Apr 28 05:40:00.595 MNL: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0/1/0, changed state to up
Apr 28 05:40:46.247 MNL: %BGP-5-ADJCHANGE: neighbor 10.63.205.129 Up
Apr 28 16:06:41.448 MNL: %CELLWAN-2-MODEM_DOWN: Modem in HWIC slot 0/0 is DOWN
Apr 29 07:07:24.737 MNL: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
Apr 29 07:07:25.737 MNL: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
Apr 29 07:10:27.737 MNL: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to up
Apr 29 07:10:28.737 MNL: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to up
sh version
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M2, RELEASE SOFTWARE (fc1) Technical Support: ttp://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Mon 26-Sep-11 17:37 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M12, RELEASE SOFTWARE (fc1)
PHILAM-BLY-BR01 uptime is 2 days, 13 hours, 53 minutes
System returned to ROM by reload at 19:00:00 MNL Fri Apr 26 2013
System restarted at 19:01:31 MNL Fri Apr 26 2013
System image file is "flash0:c2900-universalk9-mz.SPA.151-4.M2.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2911/K9 (revision 1.0) with 479232K/45056K bytes of memory.
Processor board ID FGL15481448
4 FastEthernet interfaces
3 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
3 terminal lines
1 Virtual Private Network (VPN) Module
2 Cellular interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2911/K9          FGL15481448
Technology Package License Information for Module:'c2900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      securityk9    Permanent      securityk9
uc            None          None           None
data          None          None           None
Reload scheduled for 19:00:00 MNL Mon Apr 29 2013 (in 10 hours and 4 minutes) by
jvi01131990 on vty0 (10.49.135.135)
Reload reason: Reload Command
Pinoy pala.
Do you have any other routers exibiting similar behaviour?
The only fix is to disable/enable the port, I presume?
Have you tried upgrading the IOS?
The only solution i got is to reload the router. But i need to identify whats causing it. Is it maybe RSSI? or idle?
No, I don't think so.  Could be the following factors:
1.  IOS fault or bug;
2.  HWIC not properly insterted,
3.  Faulty HWIC; or
4.  Faulty slot.
Last few weeks our field engineer installed new router to one of my handled sites, and right now i'm still having the same issue.
So you have multiple hardware exibiting the same symptoms?
right now i'm handling 71 sites, and some areas where at the rural side, which means expected to get low signal in there. And most sites that are in the rural areas experience this symptoms.
IF what I'm reading is correct, that you have some sites where the  HWIC goes down/down then I'm now leaning towards an IOS bug.
You can either raise a Cisco TAC or upgrade the IOS of one of them (for testing).
I don't really have the experience to upgrade IOS. Can you help me with it? What are some requirements that i must do first to upgrade it.
IOS upgrade for Cisco routers and switches are not difficult (once you get the hang of it).
1.  Go to Cisco Download Software website.  If you have a valid Service Contract, you can download the IOS.
2.  Download the necessary IOS you want.
3.  IMPORTANT:  Compare the MD5 hash of the file against the one in the Cisco website.
4.  Download and install TFTPd32/TFTPd64.
5.  The command to copy the IOS BIN file to the appliance is:  copy tftp:///filename.bin flash:
You enter the above command in the router.
6.  Once copy is complete, it won't hurt to compare the MD5 hash against the Cisco website.  The command to display the MD5 hash from a Cisco router or switch is:  verify /md5 flash:IOS.bin
If i upgrade the IOS, all my configurations will be lost? or do i need to backup first?
Your configurations will not be lost.
It would be a good idea to backup the configs first before you perform the upgrade.
Is there other options than upgrading the IOS? I'm not good at this.
