When Tagged AP clients not receiving dhcp address
MSDelamater
Having an problems passing dhcp traffic between Unifi APs and 1121-4p router.  Physical layout is:
1121-4 Router --> SG200 switch -->TLS circuit --> UAP-AC-SHD
When the APs are using default vlan, clients and APs receive dhcp addresses.  10.20.30.x  When I switch the SSID to use VLAN30.  The APs receive 10.20.30.x addresses but clients do not.  Have tried setting 10.20.20.1 as the IP helper-address in VLAN30 but it did not solve the issue.
Below is the run from the router, show vlan, show ip route, SG200 port/vlan connections.
Mark.
PoplarRC#show vlan
VLAN Name Status Ports
1 default active Gi0/1/2, Gi0/1/3
10 VLAN0010 active
30 VLAN0030 active Gi0/1/0, Gi0/1/1
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0 0
10 enet 100010 1500 - - - - - 0 0
30 enet 100030 1500 - - - - - 0 0
1002 fddi 101002 1500 - - - - - 0 0
1003 tr 101003 1500 - - - - - 0 0
1004 fdnet 101004 1500 - - - ieee - 0 0
1005 trnet 101005 1500 - - - ibm - 0 0
Primary Secondary Type Ports
PoplarRC#
PoplarRC#show ip route
Gateway of last resort is 172.87.0.1 to network 0.0.0.0
S* 0.0.0.0/0 [254/0] via 172.87.0.1
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 10.20.20.0/24 is directly connected, Vlan1
L 10.20.20.1/32 is directly connected, Vlan1
C 10.20.30.0/24 is directly connected, Vlan30
L 10.20.30.1/32 is directly connected, Vlan30
172.87.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.87.0.0/21 is directly connected, GigabitEthernet0/0/1
L 172.87.4.26/32 is directly connected, GigabitEthernet0/0/1
199.59.116.0/32 is subnetted, 1 subnets
S 199.59.116.1 [254/0] via 172.87.0.1, GigabitEthernet0/0/1
PoplarRC#
PoplarRC#show run
Building configuration...
Current configuration : 7690 bytes
! Last configuration change at 10:34:04 UTC Wed May 25 2022
version 17.5
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
platform hardware throughput crypto 50000
hostname PoplarRC
no aaa new-model
ip name-server 64.90.65.2 64.90.65.5 8.8.8.8
ip dhcp excluded-address 10.20.20.1 10.20.20.10
ip dhcp excluded-address 10.20.30.1 10.20.30.10
ip dhcp excluded-address 10.20.10.1 10.20.10.10
ip dhcp pool PoplarPool1
import all
network 10.20.20.0 255.255.255.0
default-router 10.20.20.1
dns-server 8.8.8.8 8.8.4.4 10.20.20.1
lease 0 4
ip dhcp pool PoplarPool2
import all
network 10.20.30.0 255.255.255.0
default-router 10.20.30.1
dns-server 8.8.8.8 8.8.4.4 10.20.30.1
lease 0 4
ip dhcp pool PoplarPool3
import all
network 10.20.10.0 255.255.255.0
default-router 10.20.10.1
dns-server 8.8.8.8 8.8.4.4 10.20.10.1
lease 0 4
login on-success log
subscriber templating
crypto pki trustpoint TP-self-signed-767876715
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-767876715
revocation-check none
rsakeypair TP-self-signed-767876715
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain TP-self-signed-767876715
certificate self-signed 01
28
quit
license udi pid C1121-4P sn FGL2608L9LX
memory free low-watermark processor 70642
diagnostic bootup level minimal
username admin privilege 15 password
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
no ip address
ip nat outside
shutdown
negotiation auto
interface GigabitEthernet0/0/1
ip dhcp client hostname PRC
ip dhcp client update dns
ip address dhcp
ip nat outside
negotiation auto
interface GigabitEthernet0/1/0
switchport access vlan 30
interface GigabitEthernet0/1/1
switchport trunk native vlan 10
switchport trunk allowed vlan 10,30
switchport mode trunk
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface Vlan1
ip address 10.20.20.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Vlan10
ip address 10.20.10.1 255.255.255.0
ip nat inside
interface Vlan30
ip address 10.20.30.1 255.255.255.0
ip helper-address 10.20.20.1
ip nat inside
no ip http server
ip http authentication local
ip http secure-server
ip http client source-interface GigabitEthernet0/0/1
ip forward-protocol nd
ip nat inside source list NATout interface GigabitEthernet0/0/1 overload
ip nat inside source list NATout2 interface GigabitEthernet0/0/0 overload
ip access-list standard NATout
10 permit 10.20.20.0 0.0.0.255
20 permit 10.20.30.0 0.0.0.255
30 permit 10.20.10.0 0.0.0.255
ip access-list standard NATout2
10 permit 10.20.30.0 0.0.0.255
20 permit 10.20.20.0 0.0.0.255
SG200 Switch
GE1 Trunk 10UP 30T 50T Connects to unmanaged switch which Unifi APs connect to
GE9 Trunk 10UP 30T 50T Connected to Router Gi0/1/0
GE18 Trunk 1UP Connected to Router Gi0/1/3
Before creating the vlan10 and its dhcp setting,  I had tried setting interface GigabitEthernet0/1/1, switchport mode trunk.
Deleted the switchport-access setting.
Current config.
Performed the cable switch late afternoon.  The APs and Clients are now being assigned.  10.20.10.x addresses.
Later tonight I will test switching the clients to vlan30.
-Mark
5 Replies 5
 Not familiar with Unifi APs but it seems to me that your missing trunk between switch and AP. If you want to send SSID traffic to a specific vlan, then, you need to extend this vlan using trunk from the switch up to the AP.
 when using default vlan, which must be the Native vlan, it works because this vlan is not tagged, so you dont need trunk for that.
Since the C1121-4P has both a switch and router built in.  It causes a bit of confusion on my part.
Presently Gi0/1/0 is set to :
I have tried connecting the SG200 to Gi0/1/1 in trunk mode but have not had success:
Presently Gi0/1/1 is set to:
Before I switch the cable from the SG200 to Gi0/1/1, do you see any changes that need to be made to Gi0/1/1?
this config is not good:
Or you config the interface as access or trunk, no both.
Take this line "switchport access vlan 30" off
For start and to keep it simple, as you are still implementing, config like this:
Current config.
-Mark
Switched the clients to use VLAN30 and they got 10.20.30.x addresses.   It is now working as intended,  Thanks.
