where can i find cisco technical documentation?
vinothlb1
Leo Laohoo
Depends on what subject matter you have in mind.
Are you looking for Data Sheets? Configuration Guides? Configuration Examples, Technology White Papers?
Can you provide some specific details?
Lucien Avramov
Level 10
Level 10
the search engine on cisco.com website is pretty good.
On the home page, its on the upper right part. You can find most of the documentation by using that field.
Giuseppe Larosa
Hello Vinoth,
start from here:
http://www.cisco.com/cisco/web/psa/default.html
from cisco home page -> quick links on the right side -> documentation
A web page is presented to you with three columns
starting from leftmost you can choice:
products
technologies
end of sale
from products you can look for IOS or for routers or switches.
you need to select from leftmost column and then the page is refreshed and you make a choice on the next column
Hope to help
Giuseppe
