Where is VTP config info stored?
Samuel8rown
I notice that many vlan & vtp configuration commands don't appear in the config file for integrated IOS. What's a quick way to see and back up the current vlan & vtp configuration information? Ideally, what I'd like is something like the config file that I can save to restore if my core switch/VTP server melts.
Jon Marshall
Vlan information is stored in a file called vlan.dat which is located in flash. You can copy it to a tftp server for backup.
To view the vlans -
"sh vlan"
to view VTP info
"sh vtp status"
Jon
Turns out on my system (6509 w/ Sup720) that vlan.dat showed up in const_nvram:, but otherwise, spot on.
Thanks, man.
