whether Netflow is supported Cisco 3750G ?
chakarav7
I have a 3750X and 3750G switches in stack and i want to know if I can configure netflow with it. I need to upgrade the IOS or change the NM Module?
please find the show version and show inventory.
------------------ show version ------------------
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:59 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02D00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
Core-Zone1 uptime is 9 weeks, 5 days, 18 hours, 42 minutes
System image file is "flash:c3750-ipbasek9-mz.122-55.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-24PS (PowerPC405) processor (revision F0) with 131072K bytes of memory.
Processor board ID FOC1223Z192
Last reset from power-on
24 Virtual Ethernet interfaces
72 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:22:0C:45:F5:00
Motherboard assembly number : 73-10217-07
Power supply part number : 341-0108-03
Motherboard serial number : FOC122314JQ
Power supply serial number : DCA1222A2SZ
Model revision number : F0
Motherboard revision number : B0
Model number : WS-C3750G-24PS-S
System serial number : FOC1223Z192
Top Assembly Part Number : 800-26855-01
Top Assembly Revision Number : D0
Version ID : V05
CLEI Code Number : CNMWR00ARC
Hardware Board Revision Number : 0x09
Switch Ports Model SW Version SW Image
1 28 WS-C3750G-24TS-1U 12.2(55)SE5 C3750-IPBASEK9-M
2 18 WS-C3750X-12S 12.2(55)SE5 C3750E-IPBASEK9-M
* 3 28 WS-C3750G-24PS 12.2(55)SE5 C3750-IPBASEK9-M
Switch 01
Switch Uptime : 9 weeks, 5 days, 18 hours, 42 minutes
Base ethernet MAC Address : 00:22:0C:AA:50:80
Motherboard assembly number : 73-10219-07
Power supply part number : 341-0098-02
Motherboard serial number : FOC12241NP2
Power supply serial number : AZS12200796
Model revision number : E0
Model number : WS-C3750G-24TS-S1U
System serial number : FOC1224Z1ST
Top assembly part number : 800-26859-01
Top assembly revision number : C0
Version ID : V03
CLEI Code Number : CNMWS00ARC
Switch 02
Switch Uptime : 9 weeks, 5 days, 18 hours, 39 minutes
Base ethernet MAC Address : D4:8C:B5:33:FD:80
Motherboard assembly number : 73-13329-03
Motherboard serial number : FDO16231PZH
Model revision number : A0
Motherboard revision number : A0
Model number : WS-C3750X-12S-S
Daughterboard assembly number : 800-32727-02
Daughterboard serial number : FDO16221XZS
System serial number : FDO1623Z11M
Top assembly part number : 800-35090-01
Top assembly revision number : B0
Version ID : V01
CLEI Code Number : CMMFG00ARA
License Level : ipbase
License Type : Permanent
Next reboot licensing Level : ipbase
------------------ show inventory ------------------
NAME: "3", DESCR: "WS-C3750G-24PS"
PID: WS-C3750G-24PS-S , VID: V05 , SN: FOC1223Z192
NAME: "GigabitEthernet3/0/27", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: AGJ1813R0J4
NAME: "1", DESCR: "WS-C3750G-24TS-1U"
PID: WS-C3750G-24TS-S1U, VID: V03 , SN: FOC1224Z1ST
NAME: "GigabitEthernet1/0/25", DESCR: "1000BaseSX SFP"
PID: Unspecified , VID: , SN: FNS121708V0
NAME: "GigabitEthernet1/0/26", DESCR: "1000BaseSX SFP"
PID: Unspecified , VID: , SN: FNS12170Q9U
NAME: "GigabitEthernet1/0/27", DESCR: "1000BaseSX SFP"
PID: Unspecified , VID: , SN: FNS121708U3
NAME: "GigabitEthernet1/0/28", DESCR: "1000BaseSX SFP"
PID: Unspecified , VID: , SN: FNS121708TX
NAME: "2", DESCR: "WS-C3750X-12S"
PID: WS-C3750X-12S-S , VID: V01 , SN: FDO1623Z11M
NAME: "Switch 2 - Power Supply 0", DESCR: "FRU Power Supply"
PID: C3KX-PWR-350WAC , VID: V02 , SN: LIT16220QAQ
NAME: "GigabitEthernet2/0/1", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS15302181
NAME: "GigabitEthernet2/0/2", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS1530217N
NAME: "GigabitEthernet2/0/3", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS1530208K
NAME: "GigabitEthernet2/0/4", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS153021TV
NAME: "GigabitEthernet2/0/5", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS15302173
NAME: "GigabitEthernet2/0/6", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS153020SD
NAME: "GigabitEthernet2/0/7", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS1530205P
NAME: "GigabitEthernet2/0/8", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS1530205E
NAME: "GigabitEthernet2/0/9", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS15310C5J
NAME: "GigabitEthernet2/0/10", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: AGJ1813R1TZ
NAME: "GigabitEthernet2/0/11", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS15310C6P
NAME: "GigabitEthernet2/0/12", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS153020U1
NAME: "Switch 2 - FRULink Slot 1 - FRULink Module", DESCR: "FRULink 1G Module"
PID: C3KX-NM-1G , VID: V01 , SN: FDO1623210K
NAME: "GigabitEthernet2/1/1", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS15310C33
NAME: "GigabitEthernet2/1/2", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS153108BF
NAME: "GigabitEthernet2/1/3", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS15310C7B
NAME: "GigabitEthernet2/1/4", DESCR: "1000BaseSX SFP"
PID: GLC-SX-MMD , VID: V01 , SN: FNS153020AC
5 Replies 5
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I only recall Netflow being supported on a 3750X with a special uplink module (C3KX-SM-10G), and I also recall it only supported Netflow for the module's ports.
Hi, Netflow is not supported on the 3750G. HTH, Roop
roor
Please check the config guide of 3750G , there will be no mention of netflow support. Whereas on the 3750X, it is supported with the specific uplink module as Joseph as mentioned. Please refer to the 3750X configuration guide for the same.
Roopa
Thanks for your commands..
could you please share the documents.
thanks..
Disclaimer
Posting
Should be in the IOS reference manual and guide for the IOS version that supports.
