Which catalyst switch modules are compatible across switching platforms and families?
tim.visser
Frequent Visitor
Frequent Visitor
Which modules from 3750 can work in other switches like 3850, 3650X, etc.?  For example, can a service module be pulled from 3750 & used in 3850?
bimckenz
Level 2
Level 2
Directly from Cisco Q & A:
Q. Are the uplinks between the Cisco Catalyst 3850 and the 3750-X interchangeable?
A. No, the uplink modules from the 3750-X are not compatible with the Cisco Catalyst 3850.
