Which Cisco switches are stackable?
HenryNguyen89
Frequent Visitor
Frequent Visitor
I knew we can stack physical switches into a Logical switch.
But i don't know which switches are stackable? And how to know they can?
If you know, please share to me.
Many thanks.
pieterh
maybe an obvious answer: search for keyword "stack" in datasheets ?
Cisco Switch Selector - Cisco
balaji.bandi
Most of the cisco model datasheet will have this information, either they can be stackable or has stack port.
so if you can refer the switch models it will give you feature information.
BB
waqas.arshad
Level 3
Level 3
You can check relevant datasheet. Normally  Cisco Catalyst 9200, Catalyst 9300, 2960X series, Catalyst 3850 series, Catalyst 3650 series, etc are supporting Stackwise Technology.
Waqas Arshad
Road2CCIE
Frequent Visitor
Frequent Visitor
Hi Henry,
Where do you want to use those switches? Access, Distribution or Core? Depending on your requirements you can find the most suitable product for your needs.
Andrew!
