which ios command to monitor packets
sarahr202
Level 5
Level 5
Hi everybody
Which ios command we can use to see as the packets enter or leave a particular port on cisco ios switches or router?
Here is my setp up
sw--- etherchannel---routed ports Router
I want to see which interface in etherchannel selects to send ip packets. We could use wireshark but my computer is pretty slow so I am wondering is there any particular ios command will do the job.
thanks and have a great weekend.
Hi Sarah
Try the PDF
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Try looking at this link
http://www.cisco.com/en/US/tech/tk389/tk213/technologies_tech_note09186a0080094714.shtml
There ar good tips here on how to work out which way traffic flows
Alex.
Thanks Alex.
When I tried to open the link that is what i got:
The file or application you are trying to access may require additional  entitlement or you are trying to access a file with an invalid name.  Additional entitlement levels are granted based on a users relationship  with Cisco on a per-application basis.
Hi Sarah
Try the PDF
Alex.
Thanks Alex
