which layer 3 switch model Only need 8 port or less
Dear all,
         Anybody can advice me which model layer 3 switch will support for below.
-          Route between VLANs
-          DHCP Server for the different VLANs
-          Connect the 2 switches
advancely thanks.
regards
10 Replies 10
Leo Laohoo
3560CG-8 with IP Services license will do.
WS-C3560-8PC-S
Jawad
According to all the cisco docs, 3560-CG-8 does not support IP-Services.  In spite of all the Post that you can upgrade.
If this is not correct, send me a link and or part number that supports that view.    None of the 3560-C support IP Services license.
(Catalyst Switch 3560-C IP Services) BGP Features:
Support for 4 byte BGP ASN numbers
BGP support for malformed attribute error handling
BGP support for Cisco-BGP-MIBv2
BGP support for graceful shutdown
BGP support for Add-Path
BGP support for VRF dynamic route leaking (for VRF lite)
2960-C and 3560-C Series Switches use a licensing model for software images. Both operate on a universal software image. The 2960-C model supports LAN Base and LAN Lite. 3560-C Series supports IP Base on all models. No IP Services support
You can't order it with IP services and there is no license to upgrade.   So how do you get IP Services?
I am suspecting upgrade to the CPU hog-prone 15.2(1)E and invoke the license PAK.
Interesting,
That's the only place on CCO that states 3560-C IP Services
All other FAQ, release notes, etc, say IP Services is not supported.
Don't get me started.  Oh please, don't get me started.
Yeah.  Cisco documentation has taken a deep dive for the last few years now.  It's going to get worst soon when Cisco management will be announcing the YEARLY "restructuring" exercise which means less and less people updating documentaion.
Note
Do not activate the demonstration license for IP services on the switch, as it is not supported by Cisco.
Hmmmm ... That'll be interesting.  You may need to create a TAC Case just to make sure this is not a document "bug".
GWINVILLE 3750-C license
GWNVLECOMPACC1-4#show lic
Index 1 Feature: advipservices
        Period left: 0  minute  0  second
Index 2 Feature: ipservices
        Period left: 6  days 6  hours
        License Type: Evaluation
        License State: Active, In Use
        License Priority: Low
        License Count: Non-Counted
Index 3 Feature: ipbase
        Period left: Life time
        License Type: Permanent
        License State: Active, Not in Use
        License Priority: Medium
Got this off one of the customers switches.   But when it expires there is no way to reactivate.  They don't want to lose functionality since they have quite a few in service.
Found this:
The Catalyst 3560-C does not support the IP services image.
Note Do not activate the demonstration license for IP services on the switch, as it is not supported by Cisco.
