After upgrading my 2960-S PoE switches webinterface dont work
ove.braathen
Hello.
i am no wizz when it comes to switches , and normaly use the webinterface , or cisco network assistance for most things
but after upgrading the ios from 12.2  to 15.x  i have had issues with with webinterface and using CNA ..
i can access the switches oki and all... but when i try to go into tabs for port settings etc from web , the links dont work ... nothing happning when i click
when i use the CNA to go into a port to change or view settings , it just hangs , and no response...
i upgraded using the CNA module or Webinterface ..
image :
c2960-lanbasek9-mz.150-1.SE3.bin
any clues `?
XXXX#show flash
Directory of flash:/
    2  -rwx         736  Apr 12 1993 11:02:21 +02:00  vlan.dat
  605  -rwx        1918  Nov 26 2013 14:32:45 +01:00  private-config.text
    4  -rwx        4120  Nov 26 2013 14:32:45 +01:00  multiple-fs
    5  -rwx        4219  Nov 26 2013 14:32:45 +01:00  config.text
    6  drwx         512  May 16 2013 12:03:30 +02:00  c2960s-universalk9-mz.150-                                     2.SE2
57931776 bytes total (38452736 bytes free)
XXXX#
Jose Solano
Level 4
Level 4
For the CNA to work you need to use a .tar IOS image, are you using a .tar image? Because I see that you included
image : c2960-lanbasek9-mz.150-1.SE3.bin which is a .bin image and does not work with CNA.
See also the release notes for the IOS you are using:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/15.0_1_se/release/notes/OL25301.html#wp1042542
Hope this helps.
glen.grant
   I'm a little confused , you say you used  c2960-lanbasek9-mz.150-1.SE3.bin  , but in your dir flash:  it says  c2960s-universalk9-mz.150- 2.SE2  which is in a directory which means it should have all the html files.  If you do a show version what version is it running ?  I would also look for bugs in the 15 code for cna, 15 has had more than its share of issues.   Also check your cna level.
CNA Compatibility
Cisco IOS 12.2(50)SE and later is only compatible with Cisco Network  Assistant (CNA) 5.0 and later. You can download Cisco Network Assistant  from this URL:
http://www.cisco.com/pcgi-bin/tablebuild.pl/NetworkAssistant
