Which model is suitable ?
Eng.mwc
I have the inquiry which have not mentioned any model but they have written the main feature which are :-
1. Multilayer switch feature card with IOS, IP/IPX and W/VIP
2. Supervisor engine with the following feature:-
512-MB DRAM,
Policy feature card
64 MB boot flash drive and software
3. Switch Fabric module
4. 12 port 40 GB ethernet module
5. 24 port 10 GB ethernet module
6. 48 port GB ethernet module
7. Network analysis module
8. RMON Agent License
Those are all different products 1-8
if anyone can inform me that which cisco models will be used here that will be a great help.
Paul Chapman
Level 4
Level 4
Hi -
The spec you've been given is a little odd (maybe outdated), but you're likely looking for a Catalyst 6513 and line cards that meet the spec.
PSC
Thanks Paul really appreciate your reply i will search on it
