Which Serial cable i need to connect serial port of 2 Routers
mahesh18
Level 6
Level 6
Hi all,
I have 2 routers with Serial ports.
I need to connect them with serial cable.
Router 1  2650XM
When i do sh ver  it shows
1 serial interface
Router 2   2620
when i do sh ver
4 Low-speed serial(sync/async) network interface(s).
Please let me know which type of serial cable should i buy?
Mahesh
Yes, try
service-module t1 clock source internal
on the DTE site and then add these commands to both side:
service-module t1 timeslots 1-24 speed 64
encapsulation hdlc
service-module t1 framing esf
service-module t1 linecode b8zs
10 Replies 10
Reza Sharifi
Hi Mahesh,
Take a look at the serial interface, are they 60 pin interfaces? If yes, you need a DTC to DCE serial cable to connect your routers back to back
Reza
Hi Reza,
Thanks for reply
i side has 60 pins other end is like rj45  and it shows
WIC-1DSU-T1=
so both ends have different connections
which cable will i need now ?
Hi Mahesh,
The interface types have to be the same.   I have never seen a cable with one side serial 60 pins and the other side Rj45.
If you can get a WIC-1DSU-T1= (Rj45) for the other router, then you simply need to by a cross over T1 cable with Rj45 on both sides.
Hi Reza,
Thanks for reply .
If i get WIC-1DSU-T1= (Rj45) for another router then both interfaces will be serial and i can connect then with cross
over ethernet cable right?
Mahesh
Mehesh,
It is called "cross over T1 cable" and not Ethernet.  The connector type is the same as Ethernet, but the pins are configured  different.  So you want to make sure you get cross over t1 cable.
Edit, you can make you own if you have the equipment but it is easier to buy one or 2
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a3f09.shtml
http://www.amazon.com/Diablo-Cable-Crossover-Individually-Shielded/dp/B005XPCWKI/ref=sr_1_9?ie=UTF8&qid=1320598655&sr=8-9
Reza
Hi Reza,
Thanks for reply again.
So in this case do i need to set clocking on 1 router  or both?
Or no need to set clocking at all?
MAhesh
Mehesh,
You don't need clocking.  Just add these 2 commands to one site to make it DTE
Hi Reza,
Thanks for  reply.
so other side will be DCE  by default?
No config needed for other router?
Mahesh
Yes, try
encapsulation hdlc
Hi Reza,
Thanks for reply
I will try that in my LAB.
MAhesh
