which switch model for traffic controller?
rechard_hk
Level 6
Level 6
Dear All,
At my office want to use main switch for traffice controller but i don't know the cisco model?
Could you let me know the model?
Main Switch (Traffic Controller) 24 ports 2-slot for 10/100 BAse TX
Best Regards,
Rechard
Ganesh Hariharan
As per my understanding you want to know the switch model which can be used for traffic controll on port based or vlan based.If yes then
cisco 3750 series
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.1_19_ea1/configuration/guide/swtrafc.html
cisco 3560 G series
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_se/configuration/guide/swtrafc.html
and even cisco 2950
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_9_ea1/configuration/guide/swtrafc.html
Check out the link for the above switches as all these switches are modular with 24 and 48 ports availabe.
Hope that helps
Ganesh.H
Leo Laohoo
What do you mean "traffic controller"?
