Which System Image do I Need?
Some consultants told us that the IOS on our 6509-E is out of support and must be upgraded.  We are using 12.2(50r)SYS2.
I cannot figure out which file(s) I need to get to do this upgrade.  I am sure it will seem easy once I understand it but until then is there a document somewhere that explains which version and revision I need?
If it helps, the current image file is s2t54-advipservicesk9_npe-mz.SPA.122-50.SY1.bin
2 Accepted Solutions
Reza Sharifi
The image goes back to 2011, but that does not mean it is out of support.  As long as you have a service contact with Cisco and the image is available online, they will support it. Now, is that a good idea to upgrade a 6 years old image, I would say yes.
Looking at Cisco IOS download page, the latest version for sup-2T is
s2t54-adventerprisek9-mz.SPA.154-1.SY1.bin
Before upgrading to any version, make sure to read all the release notes for that version.
have a look at the link below.
https://software.cisco.com/download/release.html?mdfid=283933147&reltype=all&rellifecycle=ED&relind=AVAILABLE&release=12.2.50-SY&softwareid=280805680&sortparam=2
15.4.1-SY1 is the latest release.
Reza Sharifi
I quite agree that an upgrade is in order.  I was just confused as to which image file I needed.
Thank you.  The file names make more sense now.
