12-24-2006 12:23 PM - edited 03-05-2019 01:29 PM
I have used SDM to configure a simple Modular QoS on an Ethernet Interface.
I am puzzeled by the following output :-
Why do I see 4/4 reserved conversations on the interface ???
I dont have RSVP enabled.,
cme#show queue fastEthernet 0/0
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 4/4 (allocated/max allocated)
Available Bandwidth 26000 kilobits/sec
The policy map is :-
cme#sh policy-map
Policy Map SDM-Pol-FastEthernet0/0
Description: POLICY MAP FOR FA0/0
Class SDMManage-FastEthernet0/0
Bandwidth remaining 8 (%) Max Threshold 64 (packets)
set dscp cs2
Class SDMVoice-FastEthernet0/0
Strict Priority
Bandwidth 49 (%)
set dscp ef
Class SDMRout-FastEthernet0/0
set dscp cs6
Class SDMTrans-FastEthernet0/0
Bandwidth remaining 79 (%) Max Threshold 64 (packets)
set dscp af21
Class SDMSignal-FastEthernet0/0
Bandwidth remaining 5 (%) Max Threshold 64 (packets)
set dscp cs3
Class class-default
Flow based Fair Queueing
Bandwidth 0 (kbps) Max Threshold 64 (packets)
Solved! Go to Solution.
12-29-2006 06:28 AM
Reserved conversations are seen because of the bandwidth commands used in CBWFQ, and not due to RSVP.
12-29-2006 06:28 AM
