Why does Catalyst 2960-C switch keep rebooting
torleif
We just bought a 2960-C PD 8PT switch.
The switch is delivered without powersupply. It is supposed to get power from a PoE port on another switch.
When I connect the Gigabit 1 or 2 port on the 2960-C to a PoE port on my 4507 switch the 2960-C switch starts the booting process.
After some time in the boot process:
          The password-recovery mechanism is enabled.
          64K bytes of flash-simulated non-volatile configuration memory.
          Base ethernet MAC Address       : F8:4F:57:35:8A:80
          Motherboard assembly number     : 73-12988-05
          Motherboard serial number       : FOC17243149
          Model revision number           : B0
          Motherboard revision number     : B0
          Model number                    : WS-C2960CPD-8PT-L
          System serial number            : FOC1725Y0FM
          Top Assembly Part Number        : 800-33532-01
          Top Assembly Revision Number    : D0
          Version ID                      : V01
          CLEI Code Number                : CMMDT00ARA
          Hardware Board Revision Number  : 0x01
          Switch Ports Model              SW Version            SW Image
          *    1 10    WS-C2960CPD-8PT-L  12.2(55)EX2           C2960c405-UNIVERSALK9-M
then the 4507 port is error-disable and shuts down its port - and then the 2960-C is shut down.
After some time the 4507 enables the port again, and the 2960-C starts rebooting again...
Does anyone have an idea of how to fix this??
Torleif
Leo Laohoo
This sounds like someones configured BPDUGuard as well as error-disable recovery.
Can you post the output to the command "sh run | i recovery"?
Leo Laohoo
Of course!!!
I had BPDU guard enabled.
Thank you for your help!
Torleif
Glad to be of some assistance.  Thanks for taking the time to rate our posts.
