Why does not ICMP Echos come back?
tomo456
I tried to construct catalyst2960 on Packet Tracer.
Switch>ena
Switch#conf t
Switch(config)#ena pass test
Switch(config)#line vty 0 4
Switch(config-line)#pass test2
Switch(config-line)#login
Switch(config-line)#exit
Switch(config)#int vlan 10
Switch(config-if)#ip address 192.168.1.100 255.255.255.0
Switch(config-if)#no shut
Switch(config-if)#exit
Switch(config)#ip default-gateway 192.168.1.1
Switch(config)#int fa0/1
Switch(config-if)#switchport mode access
Switch(config-if)#switchport access vlan 10
Switch#ping 127.0.0.1
Sending 5, 100-byte ICMP Echos to 127.0.0.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Why do not Echos come back?
5 Replies 5
Seb Rupik
Hi there,
Whilst on every OS a loopback interface is installed, on a multi-layer switch you need to explicitly configure it. From the output you provide this is not the case.
What is the output of sh ip int br
cheers,
Seb.
Switch#sh ip int br
FastEthernet0/1 unassigned YES manual down down
FastEthernet0/2 unassigned YES manual down down
FastEthernet0/3 unassigned YES manual down down
FastEthernet0/4 unassigned YES manual down down
FastEthernet0/5 unassigned YES manual down down
FastEthernet0/6 unassigned YES manual down down
FastEthernet0/7 unassigned YES manual down down
FastEthernet0/8 unassigned YES manual down down
FastEthernet0/9 unassigned YES manual down down
FastEthernet0/10 unassigned YES manual down down
FastEthernet0/11 unassigned YES manual down down
FastEthernet0/12 unassigned YES manual down down
FastEthernet0/13 unassigned YES manual down down
FastEthernet0/14 unassigned YES manual down down
FastEthernet0/15 unassigned YES manual down down
FastEthernet0/16 unassigned YES manual down down
FastEthernet0/17 unassigned YES manual down down
FastEthernet0/18 unassigned YES manual down down
FastEthernet0/19 unassigned YES manual down down
FastEthernet0/20 unassigned YES manual down down
FastEthernet0/21 unassigned YES manual down down
FastEthernet0/22 unassigned YES manual down down
FastEthernet0/23 unassigned YES manual down down
FastEthernet0/24 unassigned YES manual down down
GigabitEthernet0/1 unassigned YES manual down down
GigabitEthernet0/2 unassigned YES manual down down
Vlan1 unassigned YES manual administratively down down
Vlan10 192.168.1.100 YES manual up down
Switch#
Thanks for sharing the output.
As I suspected you have not explicitly configured a loopback interface with the address 127.0.0.1, and IOS does not configure one by default like a computer Operating System does. On this basis a ping to 127.0.0.1 will always fail.
cheers,
Seb.
Catalyst 2960 can not configure "Loopback."
Switch#interface Loopback0
% Invalid input detected at '^' marker.
Switch#conf t
Switch(config)#interface ?
Ethernet IEEE 802.3
FastEthernet FastEthernet IEEE 802.3
GigabitEthernet GigabitEthernet IEEE 802.3z
Port-channel Ethernet Channel of interfaces
Vlan Catalyst Vlans
range interface range command
Hi Tomo456
You can only configure Loopback in a Multilayer Switch.!!
