Why does this work? ping other subnet with no default-gateway
jpferron31
I have a lab on eve-ng with the following:2022-04-15 16_46_02-EVE _ Topology.png
 Both switches use vlan 1 by default with the ip address on the image. The switch on the right is indeed named R6. Now, I was wondering why I couldn't reach each others subnets, until I hit the no ip routing command. Now, everything pings but I don't understand why it does. Whether I put a default-gateway on each switches, or I don't, it works. I can ping from 192.168.2.2 to 192.168.1.1 and vice versa. Here are the configs of the switch:
Switch on the right (R6)
Building configuration...
Current configuration : 936 bytes
! Last configuration change at 15:42:15 EST Fri Apr 15 2022
version 15.2
service compress-config
hostname R6
boot-start-marker
boot-end-marker
no aaa new-model
clock timezone EST -5 0
no ip source-route
no ip routing
no ip cef
no ipv6 cef
spanning-tree mode pvst
interface Ethernet0/0
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Vlan1
ip address 192.168.2.2 255.255.255.0
no ip route-cache
no ip classless
ip forward-protocol nd
ip http server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
R6#
Switch on the left (SW2)
SW2#show run
! Last configuration change at 15:38:05 EST Fri Apr 15 2022
version 15.2
hostname SW2
boot-start-marker
boot-end-marker
no aaa new-model
no ip source-route
no ip routing
no ip cef
no ipv6 cef
interface Vlan1
no ip route-cache
no ip classless
ip http server
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
login
end
SW2#
Why can I ping everything here? In the CCNA volume 1 book, it mentions that you need to add a default-gateway on the switch so it can communicate with other subnets in case you want to telnet or SSH into the switch. In this case, it's working without it. Is this a dumb question to ask? Thanks for your help.
If it helps, R6 is a Cisco IOL Layer 2 device. Also, I tried adding the no ip classless command, but I have no idea what it does; so please ignore.
Jon Marshall
The router will be using proxy arp and that is why it works.
If the switch has no default gateway it will arp for everything so it arps for 192.168.1.1, the router sees this arp and because it has a directly connected interface in that subnet it answers of behalf of 192.168.1.1 using the mac address of it's fa0/1 interface.
The switch then just sends the packet to the router with the router's mac address and the router forwards it on.
Jon
Jon Marshall
Jon
jpferron31
Thank you!!! I got it to work. I set the command no ip proxy-arp on the interface facing the switch and now it cannot ping unless I set the default-gateway.
I appreciate it!
