Why does this work
admin_2
Level 7
Level 7
I manage a pure ADSL WAN in Australia (g'day). Every now and again, a router will go down. The 'sync' light is still on, but their is no connectivity at all. By mistake, I accidentally rang the phone number that the adsl service lives on. Low and behold, the interface came back up instantaneously.
I have been using this technique to phone routers that have gone down, and have found that within 2-3 seconds of me phoning them, the interface comes back up. This works first time, every time for the last 4 months.
What I am really curios about, is *why* it works. Does anyone have any clues? Anyone done something similar?
scottmac
Level 11
Level 11
Maybe the ring voltage breaks through accumulated oxidation on some marginal connector.
You'd think that if your phone call would do it, calls from others would do it as well. How likely is it that yours is the first inbound call to that number for some extended length of time?
Interesting.
Does it work if you call from a cell phone or somewhere other than your office?
Good Luck
Scott
apaxson
Level 3
Level 3
It sounds like something with Australia's phone company?
I've never had those symptoms/resolutions.
adnan.zafar
Level 3
Level 3
As far as i got
your router's pppoe session hangs after some time and when u make a phone call your session becomes active because router automatically sense the session which is down and up the session again..
So when u make the call the session( which hangs)between your router and DSL Provider become active and u get connected
Basically the problem is with your router or ISP because when session terminates they show you that session is active while LED means your line is sync physically but session creation is logical connectivity between router and ISP through PPPoE ( Point to Point Over Ethernet)
Hope this may help you
