Why have sub ints on a fa?
ry0534cisco
I understand the sub-ints on  aserial WAN link, usually for frame-relay, but why the sub-ints on the fa? And how is it implemented on the LAN?  With a FR switch?
R#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES manual up                    up
FastEthernet0/0.1          10.111.80.1     YES manual up                    up
FastEthernet0/0.20         10.114.1.113    YES manual up                    up
FastEthernet0/1            unassigned      YES NVRAM  administratively down down
Serial0/0/0                unassigned      YES NVRAM  up                    up
Serial0/0/0.20             152.162.251.138 YES NVRAM  up                    up
Loopback0                  10.255.111.82   YES NVRAM  up                    up
Peter Paluch
Hello Ron,
Subinterfaces on FastEthernet interfaces are used for VLANs. If you want your router to be a member of multiple VLANs and provide inter-VLAN routing, you need to create these subinterfaces, one for each VLAN the router should be a member of. The IP address of a particular subinterface can then be used by stations in the associated VLAN as their default gateway.
Best regards,
Peter
Peter Paluch
Hello Ron,
Best regards,
Peter
OH!!!
ROAS. It skipped my mind. Thanks Peter.
Hi Ron,
You are very much welcome. Thank you for the rating!
Best regards,
Peter
