Why I can't reach a distant LAN IP of a router, from a PC and not from a router?
nonstopper
When I try to trace the LAN of a router from another cisco router, it stops on the WAN, but when trying from a  Win7 PC it reaches.
Is there a reason?
Thanks.
6 Replies 6
devils_advocate
Level 7
Level 7
It depends on what it uses as the source address when you traceroute from a Router.
The wan. And there is a public IP there
Have you checked that there are routes on the return path for the router IP.
Jon
Well, I don't have access to the distant router to perform a bi-directional, but what I understand is that if the ping responds successfully is because both routes are know, correct?
The strange is that pinging from a PC it goes correctly.
Windows uses icmp for traceroute whereas Cisco uses UDP. Your traffic on the other end may be allowing icmp messages through, but not udp. I believe Linux uses udp as well, so if you have access to a Linux server and this is the cause, you should see the same result as the router does.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Yes, but if the PCs IP may be from a different IP subnet than the routers IP so havng routes for the PC's IP does not necessarily mean there are routes for the router's IP.
Jon
