Fastethernet0 management interface on 3750-x switch
Bob Cowley
Hi,  Is this interface MDI or MDI-X by default?
5 Replies 5
cadet alain
show controllers ethernet-controller fastethernet0 phy should tell you this.
Alain
Hi, I've run that command, but I can't see where it give the mdi setting?
S02-EXT#sh controllers ethernet-controller f0 phy
FastEthernet0
hw_if_index = 6478 if_number = 6478
PowerPC405 FastEthernet unit 0
PHY Hardware is Broadcom BCM5220 rev. 4 (id_register: 0x40, 0x61E4)
rx_intr: 0 tx_intr: 0 mac_err_isr: 0 phy_link_isr:0
Current station address 5057.a8c5.81b7, default address 5057.a8c5.81b7
MAL register dump:
malcr        0x00004082  0x100
malesr       0x00000000  0x101
malier       0x00000000  0x102
maltxcasr    0x00000000  0x104
maltxcarr    0x00000000  0x105
maltxeobisr  0x00000000  0x106
maltxdeir    0x00000000  0x107
malrxcasr    0x00000000  0x110
malrxcarr    0x00000000  0x111
malrxeobisr  0x00000000  0x112
malrxdeir    0x00000000  0x113
maltxctp0r   0x0E027880  0x120
malrxctp0r   0x0E0272C0  0x140
malrcbs0   0x00000060  0x160
EMAC register dump:
emacmr0      0xC0000000  0x00
emacmr1      0x815A8020  0x04
emactmr0     0x00000007  0x08
emactmr1     0x7807C000  0x0C
emacrmr      0x7D180000  0x10
emacisr      0x00000002  0x14
emacier      0x00000000  0x18
emaciah      0x00005057  0x1C
emacial      0xA8C581B7  0x20
emacptr      0x0000FFFF  0x2C
emaclsah     0x00000000  0x50
emaclsal     0x00000000  0x54
emacipgr     0x00000004  0x58
emacstacr    0x0010131E  0x5C
emactrtr     0x03000000  0x60
emacrwmr     0x07801000  0x64
emacoctx     0x00000000  0x68
emacocrx     0x00000000  0x6C
UIC register dump:
uicsr      0xF5C7FFF4  0xC0
uicer      0x02300008  0xC2
uicmsr     0x00000000  0xC6
PHY register dump:
3100 7809 0040 61E4 3000 0000 0004 2001 0000 0000 0000 0000 0000 0000 0000 0000
3000 0001 0000 0000 0200 0600 0200 0000 003C 1002 9F10 008A 002C 0000 0010
RX ring with 0 entries at 0xE0272C0, Buffer size 1524
Rxhead = 0x0 (-29380184), Rxp = 0x0 (-19906165)
TX ring with 0 entries at 0xE027880, tx_count = 0
tx_head = 0x0 (-29380368), head_txp = 0x0 (-19906188)
tx_tail = 0x0 (-29380368), tail_txp = 0x0 (-19906188)
0 missed datagrams, 0 overruns
0 transmitter underruns, 0 excessive collisions
0 single collisions, 0 multiple collisions
0 dma memory errors, 0 CRC errors
0 alignment errors, 0 runts, 0 giants
emac/mal specific errors:
0 rx in range, 0 rx out range
0 mal_rx_serr, 0 mal_tx_serr
0 mal_rx_de, 0 mal_tx_de
0 mal_multi_desc
0 emac_int
0 mal_err_isr
0 SQE errors, 0 tx CRC errors
0 output queue fail
Auto-MDIX is enabled by default. When you enable auto-MDIX, you must also set the interface speed and duplex to
auto so that the feature operates correctly. Auto-MDIX is supported on all  10/100/1000-Mb/s and on 10/100/1000BASE-TX small form-factor pluggable  (SFP)-module interfaces. It is not supported on 1000BASE-SX or -LX SFP  module interfaces.
Thanks, I need to set the interface statically to 100/full though so I can't use auto mdix.  It is specifically the management interface on this switch that I'm using so I need to know if I should be using a straight through or crossover cable to connect to my management switch.
I've always used straight through Cat 5 patch cables for those interfaces and never had any problem connecting them to other switches that way.
