Why is configuring a 4321 router difficult? (Any help would be greatly appreciated - am desperate)
There needs to be a simple graphical interface to get these units going.
Eventually we will be using the more advanced features of this unit, but right now we just want to get it running as a router.
I have figured out how to talk to it through a terminal program
I have managed to set the time/date
I even got the simple web interface to work
The graphical interface requires that a user ID be created.
I entered the following "username admin privilege 15 secret admin" and it appears to have accepted it (I did not enter the "line vty 0 15" command or the "login local" command as shown in the following thread: https://supportforums.cisco.com/t5/lan-switching-and-routing/username-and-password/td-p/3226098 as that after the "line vty 0 15" it is prompting me for something that is not documented in the answer.
But I digress.
- I need to set this unit up with an address of 192.168.1.1 (aka the "gateway" address used in Windows) I'm assuming on the top ethernet port (0/0/1) with the bottom ethernet port (0/0/0) going to the ADSL modem.
- Then turn on the DHCP server if it's not defaulted on - with a starting address of 192.168.1.100.
- Then I need to enter my PPPoE login information.
- And finally, I need to have that information written to permanent memory so it's still there after a power failure (I found that I have to keep configuring the simple web access every time I power the unit down to try programming it again.)
Can anyone please help?
I was supposed to install this unit on Christmas day and if I miss tomorrow, New Year's Day, I'll have to wait until Easter when the store is closed and I can take the network down.
While the manual does mention DHCP - I have no clue as to what it is talking about and it's late (I spent most of day figuring out how the get the simple web interface to work and trying to unsuccessfully create a user ID to use the graphical web interface.)
And the manual does not appear to cover the PPPoE part (or at least it's not coming up in a text search, nor does ADSL, and the only discussion on Modems appear to be about the one used to connect to the unit to remotely access it.)
Thanx in advance
A Very Desperate Person
6 Replies 6
Peter Paluch
It would be helpful if we could see your current state of configuration to understand how to integrate the additional settings into it.
Would you be so kind to run the show running-config command, capture the entire output, and post it here? We can take it from there.
Best regards,
Peter
I've copied it in its entirety including the "!''s that have noting next to them. (Is there a way to get rid of the "more" and have it just dump it all to the screen? I end up leaning on the Return key to speed it up then have to scroll up a few pages of prompts.)
Bloor_Router#show running-config
Building configuration...
Current configuration : 1499 bytes
! Last configuration change at 16:11:36 UTC Sun Dec 31 2017
version 15.5
no platform punt-keepalive disable-kernel-core
hostname Bloor_Router
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
enable secret 5 $1$d2AV$.x62c8AIL9dVKFN/m1Q61.
enable password Bloor
no aaa new-model
ethernet lmi global
no process cpu autoprofile hog
subscriber templating
license udi pid ISR4321/K9 sn FDO21112KP2
username admin privilege 15 secret 5 $1$1GEr$xjUl2.RVLPwcDxUbMjnNp0
redundancy
 mode none
vlan internal allocation policy ascending
no cdp run
interface GigabitEthernet0/0/0
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet0/0/1
 no ip address
 shutdown
 negotiation auto
 vrf forwarding Mgmt-intf
 ip address 192.168.1.250 255.255.255.0
 negotiation auto
 no cdp enable
interface Vlan1
 no ip address
 shutdown
ip forward-protocol nd
ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
snmp-server community public RO
control-plane
line con 0
 exec-timeout 0 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password BloorRemote
 login local
line vty 5 15
 login
end
Bloor_Router#
do you have access to the command line ? It should look like this:
4321#
I've gotten that far (even assigned a password after answering "y" to running the auto config after one of the many power off/on restarts.)
here is a generic sample configuration. Certain information such as PAP username and password might have been given to you by your provider. IP addressing is obviously arbitrary.
In order to display the entire configuration without any breaks, configure 'terminal length 0' on your router:
Bloor_Router#terminal length 0
Now if you do a 'sh run' the entire configuration will be displayed. I don't think you can get rid of the line or section markers (!)...
Here is the generic config:
boot-start-marker
boot-end-marker
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ethernet lmi global
ip dhcp excluded-address 192.168.10.1
ip dhcp pool LAN
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8 8.8.4.4
redundancy
mode none
controller VDSL 0/1/0
operating mode adsl2+ annex A
ip ssh rsa keypair-name ssh_key
no ip address
shutdown
negotiation auto
ip address 192.168.10.1 255.255.255
ip nat inside
negotiation auto
negotiation auto
no cdp enable
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
no atm oversubscribe
no atm ilmi-keepalive
no atm enable-ilmi-trap
interface ATM0/1/0.1 point-to-point
no ip redirects
no ip unreachables
no ip proxy-arp
pvc 8/35
vbr-rt 969 969 1
pppoe-client dial-pool-number 1
interface Vlan1
no ip address
interface Dialer1l
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username XXXXXX password 0 XXXXX
no cdp enable
ip virtual-reassembly
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list 1 interface Dialer1 overload
ip http server
access-list 1 permit 192.168.10.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
exec-timeout 0 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
line vty 5 15
login
end
Thanks for info on the "terminal length" command.
And I see my problem regarding PPPoE, I searched on the whole word while the manual only uses "PPP" so I did not find it.
That leaves a couple of questions (more if I can't figure out the PPP section of the manual - but fist I want to get the Gateway address configured):
- Is the IP address I assign to Ethernet 0/0/1 the IP address of the "Gateway" that one enters in Windows IP4 config screen?
- Do I ignore Ethernet 0/0/0 and just plug it into the modem? Or does it too need to be configured?
The manual shows an example where 0/0/0 is set to 10.0.0.1 with 0/0/1 unassigned, 0/0/2 with 10.10.10.1 (I only have two ports so should I just substitute 0/0/1 for 0/0/2 and ignore the other lines in the example?) What is also confusing me is the example where 0/0/3 is set to 8.8.8.1 which belongs to Google and I'm wondering why, is this needed? And if so do I need more ports?
While my config shows a Lever 15 user named "admin" I cannot log into the graphical interface with it. I have posted that question here: https://supportforums.cisco.com/t5/lan-switching-and-routing/username-and-password/m-p/3226098
P.S. The PPPoE info I have from Bell Canada.
