Why OSPF command doesn't appear on a Cisco ASR 9000 router
sandisugih21
RP/0/RP0/CPU0:ASR9K#conf t
Tue Jan 21 13:30:09.588 WIB
RP/0/RP0/CPU0:ASR9K(config)#router ?
bgp BGP configuration subcommands
hsrp HSRP configuration subcommands
lisp LISP configuration subcommands
rib RIB configuration subcommands
rip RIP configuration subcommands
static Static route configuration subcommands
vrrp VRRP configuration subcommands
M02@rt37
Hello @sandisugih21
Assuming it's XR64, do you have the OSPF rpm installed?
So, make sure the package is installed.
"show install ?" to see the options. I'd go "show install activate" on asr9k to see what packages are activated...
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-6/system-setup/configuration/guide/b-system-setup-cg-asr9000-66x/b-system-setup-cg-asr9000-66x_chapter_0101.html#task_B352A894D0A24F539D9F49FA8DEE2640
Best regards
M02@rt37
Hello @sandisugih21
Best regards
Hello Mr.M02@rt37,
I checked the OSPF module and it wasn't installed:
RP/0/RP0/CPU0:ASR9K#show install active
Tue Jan 21 14:07:40.521 WIB
Label : 7.11.2
Node 0/RP0/CPU0 [RP]
Boot Partition: xr_lv0
Active Packages: 1
asr9k-xr-7.11.2 version=7.11.2 [Boot image]
Node 0/0/CPU0 [LC]
Active Packages: 1
Currently I have installed the OSPF module and the OSPF command has appeared:
Tue Jan 21 14:28:52.838 WIB
Label : 7.11.2
Active Packages: 2
asr9k-ospf-x64-1.0.0.0-r7112
Node 0/0/CPU0 [LC]
Active Packages: 2
ospf OSPF configuration subcommands
ospfv3 IPv6 Open Shortest Path First protocol (OSPFv3)
Thank you very much.
Best Regards.
Great ! You're so welcome.
Best regards
