Macsec capability on Catalyst 9300-T model
algreg
Is there macsec capability on Catalyst 9300-T switch model?
Switch Ports Model              SW Version        SW Image              Mode
     1 65    C9300-48T          16.12.02           CAT9K_IOSXE           INSTALL
*    2 65    C9300-48T          16.12.02          CAT9K_IOSXE           INSTALL
Technology Package License Information:
Technology-package                                     Technology-package
Current                        Type                       Next reboot
network-advantage       Smart License                    network-advantage
dna-advantage           Subscription Smart License       dna-advantage
Cannot find commands like "mka policy" or "sh macsec".
Based on the feature navigator it should be there. 
Am I wrong?
11 Replies 11
@algreg
 I believe this can be related with license
Hi Flavio,
I think this is requirement for WAN MACsec feature. I am asking about switch-to-switch MACsec feature.
they also mention stack and stackwise, which seems to be your case.
MACsec is not supported on stacked switches?
It is with the additional license as describded above.
Macsec is same between Sw and wan and between sw and other sw.
Note:- not all port support macsec I think only uplink support macsec
MHM
M02@rt37
Hello @algreg
Which port do yo  connect to the other switch ?
AS an example for C9300-48UN switch models, MACsec is supported only on the first 16 downlink network ports and on all uplink network module ports. MACsec is not supported on the last 32 downlink network ports of C9300-48UN switch models...
Best regards
Hi M02@rt37
The port is T1/1/1
The thing is there is no macsec related commands at all:
SW1-ST#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
SW1-ST(config)#mka pol
SW1-ST(config)#mka?
% Unrecognized command
SW1-ST(config)#m?
mab      mac                   mac-address-table  macro
macro    maintenance-template  map-class          map-list
md-list  mdns-sd               mdns-sd            media
memory   metadata              monitor            mpls
mvrp
SW1-ST(config)#mk?
SW1-ST(config)#mka
% Invalid input detected at '^' marker.
SW1-ST(config)#mka?
SW1-ST(config)#mka
SW1-ST(config)#int t1/1/1
SW1-ST(config-if)#mac?
mac  mac-address  macro
SW1-ST(config-if)#mka?
Ok @algreg
So, open a TAC case.
Best regards
I would if I had a contract.
I thought maybe someone here could give me a hint
Don't worry' if I have time I will check your issue today
Thanks for waiting
MHM
