Why SPAN port show traffic from other network.
msompong1
Hi All,
I am troubleshooting on network intermittent slow issue.
I have the connection like the picture in attached the VLAN is the server VLAN the L3 switch routing IP is 10.1.4.1/24 and the firewall for route traffic to internet and controlled segment is 10.1.4.8/24 , From the L3 I have default route to 10.1.4.8
The server also in VLAN4 with IP 10.1.4.57/24 and physical connected to L3 port with access VLAN A.
I've Wireshark to SPAN the traffic on Server A port and sometime I found huge traffic 50-300Mbps for 5-10 sec that not only communication from/to server A appear ,but from other networks like from 10.1.28.0/24 to internet or 10.1.93.0/24 to 10.1.50.0/24. Normally it should be found only broadcast and traffic from/to 10.1.4.57/24 right?
Could someone share the idea on this and which I can start to check?
Thank you.
balaji.bandi
what switch is this, can you share the config.
if you doing captgure on VLAN interface as source sure (i am assuming ) you going to see all that information.
instead you use source port as server connected port, so you see what server sending traffic (hope this works as expected)
Server A port as source ? what is this Server role in the network ?
I am troubleshooting on network intermittent slow issue.  - is the issue between client and internet or client to Server ?
BB
- The switch is Cisco4510R and the SPAN source do on the port that server A is connected not a VLAN.
- The server A is the Voice gateway with low performance resources.
- As I test SPAN from the other source port that assigned to VLAN A , I found the same issue with can see other network traffic and I think it will impact to the connected host that has the low performance like Voice gateway above.
