Why ssh does not work?
edgar-quintana
I do not know why I can not login using ssh client to my router... here is my configuration.
Best regards and thks
Try "login local" under vty.
line vty 0 4
access-class 102 in
password 7 xxxxx
login local
-Shahzad
11 Replies 11
edgar-quintana
The new configuration is:
line con 0
line aux 0
line vty 0 4
access-class 102 in
password 7 xxxxx
login
transport input ssh
transport output none
Can you remove the access-class ?
Perhaps the ACL is blocking your session.
This acl permits me to connect to, if I delete this acl I can not connect
line vty 0 4
access-class 102 in
password 7 xxxxx
login local
-Shahzad
Was login "local" command which resolved my issue.
Thks a lot..
Best regards
jsmitty10
What client are you using Putty?
I didn't see generate RSA key (crypto)
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087cac.html#84102
Edison Ortiz
1) Create a local account
Ex,
username cisco priv 15 password cisco123
2) enable login under the vty
Ex,
line vty 0 4
login
3) Read up the troubleshooting and configuration steps at this link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsec_c/part25/ch10/schssh.htm
Edgar I apologize,Edison's link is much better sorry for the confusion!
My ssh client is bitvise http://www.bitvise.com/tunnelier
There is already a root user with 15 level configured.
I use this profile to connect to but always is asking for the pass.. I use the correcto user/pass but nothing
1) Try another client such as putty or secure-crt.
2) enable login under the vty lines.
With putty..nothing
Ill try to change no login parameter
