Why these Catalyst 6880-X-LE port channel interface errors?
Hello folks. Please see below...
Device: Catalyst 6880-X-LE
VER: (c6880x-ADVENTERPRISEK9-M), Version 15.5(1)SY8, RELEASE SOFTWARE (fc3)
SYMPTOM: TenGigabitEthernet1/5/10
Received 17768 broadcasts (17650 multicasts)
     73307705 input errors
TenGigabitEthernet2/5/10
Received 331315 broadcasts (331313 multicasts)
     0 runts, 4691 giants, 0 throttles
     159842905 input errors
ALSO: These ports are in a port channel. The port channel configuration has been confirmed as healthy (full, duplex, and timers)
QUESTIONS: Whys are these errors caused?
What is the next troubleshooting step?
Thank you!
7 Replies 7
the input error with giant this may be because of other side of link use MTU higher than 6000 side.
check that.
Thank you. I am checking now,
but what about the other port with no giants, would that also be affected by the MTU setting?...
"TenGigabitEthernet1/5/10
 73307705 input errors"
can I see
show interface counter error
Thank you for your reply. Please see below...
SWITCH1#show int counters errors
Port              FCS-Err           Xmit-Err         Rcv-Err      OutDiscards
Te1/1/9       1106                    0                 1107                        0
Te1/1/10           0                    1                       0                        1
Te1/5/6             0                    0                       0                87335
Te1/5/7             0                    0                       0                63602
Te1/5/10           0                    0         34445891                        0
Te1/5/11           0                    0           8299703                        0
Te2/5/6             0                    0                        0             203746
Te2/5/7             0                    0                        0               18026
Te2/5/10           0                    0          30335146                       0
Te2/5/11           0                    0          20379920                       0
Po52                 0                    0                        0             372709
Po105               0                    0          64664664                       0
Po106               0                    0          28631545                       0
Po114               0                    0                        0                   127
Po116               0                    0                        0                   999
Po119              1095               0                  1096                       0
Port                  SQETest-Err             Deferred-Tx         IntMacTx-Err I         ntMacRx-Err         Symbol-Err
Te1/1/9                     0                             0                        0                              0                       1106
Te1/1/10                   0                             0                        0                              0                             1
Po119                       0                             0                        0                              0                       1095
balaji.bandi
clear  the counters and see how fast they increasing :
how is the utilisation of the port ? is this only 1 port / port-channel  or all interfaces ?
some troubleshooting tips :
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/24053-193.html
BB
Te1/1/10           0                    1                       0                        1
Te1/5/6             0                    0                       0                87335
Te1/5/7             0                    0                       0                63602
Te2/5/7             0                    0                        0               18026
Po52                 0                    0                        0             372709
Po114               0                    0                        0                   127
Po116               0                    0                        0                   999
Po119              1095               0                  1096                       0
Te1/1/10                   0                             0                        0                              0                             1
Po119                       0                             0                        0                              0                       1095
Leo Laohoo
Post the complete output to the command "sh interface Ten 1/5/10" & "sh interface Ten 2/5/10".
