Why we see interface TenGigabitEthernet1/1/1 ?
Hello All
When i enter " show  runnig-configuration "  in Cisco 3850 Switch i see interfaces through interface TenGigabitEthernet1/1/1 - 1/1/16 but there are no ports like that. Port numbers are 1/0/1-48 and 2/0/1-48.
Martin L
any "middle" number (y) means module in x/y/z; those are fiber uplink modules and standard low end 3850 switch supports 4 x 1 Gigabit and  4 x 10 Gigabit.
I noticed that too; c3850s have 10 Gig ports listed in config even thou there might be no such module inserted.
Regards, ML
**Please Rate All Helpful Responses **
Martin L
Regards, ML
Use sh inter status command to get the right output
Hello
The switch can support either 1 or 10gb sfps in the same module slot so the ios will show 1/10 gb interfaces in the running configuraton for the same physcal slot.
For example:
Same Physical slot
int gig1/1/1/  < 1GB
int te1/1/1  < -10gb
Kind Regards
Paul
