Why we use Wildcard Mask
Kuldeep singh
Hi experts,
I know only one thing about Wildcard mask is that it uses in standard access list for Source based restriction. that's it
So i need your suggestions with simple example so that i can understand at once .
1.What is exact use of Wildcard mask ?
2. Why we use Wildcard mask in ospf ?
KS
Bilal Nawaz
Hello Kuldeep,
A wildcard mask is a mask of bits that indicates which parts of an IP address are available for examination. In the Cisco IOS, they are used in several places, for example:
  • To indicate the size of a network or subnet for some routing protocols, such as OSPF.
  • To indicate what IP addresses should be permitted or denied in access control lists (ACLs).
A wildcard mask can be thought of as an inverted subnet mask. For example, a subnet mask of 255.255.255.0 (binary equivalent = 11111111.11111111.11111111.00000000) inverts to a wildcard mask of 0.0.0.255.
Any wildcard bit-pattern can be masked for examination: For example, a wildcard mask of 0.0.0.254 (binary equivalent = 00000000.00000000.00000000.11111110) will allow even-numbered IP addresses to be examined. A 0 octet in the wildcard mask indicates that the corresponding octet in the network must match exactly. On the other hand, a 254 indicates that you don't care what the corresponding octet is in the network except for the host(255) bit.
A network and wildcard mask combination of 1.1.1.1 0.0.0.0 would match an interface configured exactly with 1.1.1.1 only, and nothing else. This is is really useful if you want to activate OSPF on a specific interface in a very clear and simple way.
If you insist on matching a range of networks, the network and wildcard mask combination of 1.1.0.0 0.0.255.255 would match any interface in the range of 1.1.0.0 to 1.1.255.255. Because of this, it's simpler and safer to stick to using wildcard masks of 0.0.0.0 and identify each OSPF interface individually, but once configured, they function exactly the same- one way is not better than the other.
Wildcard masks are used in situations where subnet masks may not apply. For example, when two affected hosts fall in different subnets, the use of a wildcard mask will group them together.
http://en.wikipedia.org/wiki/Wildcard_mask
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
