In WS-X4606-X2-E can we use three ports for CVR-X2-SFP and three ports X2-10GB-SR
Hi i have got a customer where they have existing WS-C4506-E 6  where they have few connections .
Now they want to put two X2-10GB-SR    the other ports where using CVR-X2-SFP   .
I have a doubt that if CVR-X2-SFP  is using in first port then can i use the second port for X2-10GB-SR or that port cannot be used .
below is the show inventory of the switch
NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4506-E 6 slot switch "
PID: WS-C4506-E        , VID: V02  , SN: FOX1449HBDR
NAME: "Linecard(slot 1)", DESCR: "Supervisor 6-E 10GE (X2), 1000BaseX (SFP) with                         2 10GE X2 ports"
PID: WS-X45-SUP6-E     , VID: V08  , SN: JAE14400HOZ
NAME: "Converter 1/1", DESCR: "Converter Module"
PID: CVR-X2-SFP        , VID: V02  , SN: FDO14360FZQ
NAME: "GigabitEthernet1/3", DESCR: "1000BaseSX"
PID: Unspecified       , VID:      , SN: AGA140312B0
NAME: "GigabitEthernet1/4", DESCR: "1000BaseSX"
PID: Unspecified       , VID:      , SN: FNS1416231T
NAME: "TenGigabitEthernet1/2", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V04  , SN: FNS14360XKX
NAME: "Linecard(slot 3)", DESCR: "10GE (X2), 1000BaseX (SFP) with 6 10GE X2 port                        s"
PID: WS-X4606-X2-E     , VID: V03  , SN: JAE150303PE
NAME: "TenGigabitEthernet3/1", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V04  , SN: FNS14360KEN
NAME: "TenGigabitEthernet3/2", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V04  , SN: FNS143617X2
NAME: "TenGigabitEthernet3/3", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V04  , SN: FNS143617XA
NAME: "TenGigabitEthernet3/5", DESCR: "10Gbase-SR"
PID: X2-10GB-SR        , VID: V02  , SN: AGA12451069
NAME: "Linecard(slot 4)", DESCR: "10/100/1000BaseT (RJ45) with 48 10/100/1000 ba                        seT "
PID: WS-X4648-RJ45-E   , VID: V01  , SN: JAE151209V1
NAME: "Linecard(slot 6)", DESCR: "10/100/1000BaseT (RJ45) with 48 10/100/1000 ba                        seT "
PID: WS-X4648-RJ45-E   , VID: V02  , SN: JAE16110113
NAME: "Fan", DESCR: "FanTray"
PID: WS-X4596-E        , VID: V03  , SN: FOX1449GZUD
NAME: "Power Supply 1", DESCR: "Power Supply ( AC 1300W )"
PID: PWR-C45-1300ACV   , VID: V06  , SN: SNI1505AS47
NAME: "Power Supply 2", DESCR: "Power Supply ( AC 1300W )"
PID: PWR-C45-1300ACV   , VID: V06  , SN: SNI1505AR37
aehqcs01#sh module
Chassis Type : WS-C4506-E
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     6  Sup 6-E 10GE (X2), 1000BaseX (SFP)     WS-X45-SUP6-E      JAE14400HOZ
3    18  10GE (X2), 1000BaseX (SFP)             WS-X4606-X2-E      JAE150303PE
4    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE151209V1
6    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE16110113
M MAC addresses                    Hw  Fw           Sw               Status
1 e05f.b939.8480 to e05f.b939.8485 1.7 12.2(44r)SG5 12.2(53)SG2      Ok
3 503d.e595.ce94 to 503d.e595.cea5 1.2                               Ok
4 6400.f12b.1b61 to 6400.f12b.1b90 1.0                               Ok
6 442b.037a.3d4c to 442b.037a.3d7b 1.0                               Ok
Breeze Joseph Kuriakose Sr Network Engineer
Richard Atkin
Level 4
Level 4
Using one port with 10G SFP and a different port with the 2x 1G converter is fine... The answer to your question is 'yes'.
Hi Richard Thanks for the feedback.
i jut want to confirm
1>> If i use 1st port CVR-X2-SFP then can i use the 2 port X2-10GB-SR  or i should you in 3rd port .
2>>if first 4 ports are using CVR-X2-SFP then the remaining 2 ports can i use X2-10GB-SR
the line card is WS-X4606-X2-E
