Why won't my 1140 router turn on?
A.Barnes95
I've tried plugging my Cisco 1140 series router into an ethernet port in both my mom's house (where it formerly worked) and here in college, in order to power it with PoE. However, the light never comes on, no matter which cable I use or which port. I've also tried pressing and holding the mode button, to no avail.
I know the ethernet ports should work, as I've been using them with my PC with no problems for as long as I can remember.
Why won't it turn on?
dfboney01
What PoE source are you using?  Is it the same source you used at the other location?  It it's a switch, it must be PoE capable, and PoE usually has to be enabled for specific ports.
Leo Laohoo
Give us some info.
What kind of PoE switch are you using?
